Lifted my riders seat up to check water level in expansion bottle and i noticed the the two rubber stops in the rear seat look like they are starting to split where the mechanism for the adjustment of the seat sits .
The base of the passenger seat looks like the mechanism is starting to cause some damage .
Is anybody else having this problem and is it a warranty issue .
04 your 05
graphite in Blighty
Discussion Starter · #3 ·
seat rubbers
My dealer checked it, and then changed the rubbers under warranty .
He told me not to slam the seat shut to hard as this might damage the rubbers .
04 your 05
graphite in Blighty
changed the rubbers?
04 your 05
graphite in Blighty
mine changed out BOTH seats, and the new ones are made markedly different that the first set. looks like a completely different manufacturer. The new ones actually sit higher than the older ones, and the front is wider, and the back is a touch longer. I did check to make sure that they were the correct part #'s, and they matched up as the '05 std seat (F&R)
Discussion Starter · #5 ·
The replacement rubbers that were replaced last year are starting to split , so i rang my dealer and i asked him if anybody else has complained and he said no .
Those bits of rubber are too soft and split very easy.
Has the seat been changed on the 06 and 07 models
regards bikesnumbnuts
04 your 05 updated
in Blighty
