1 - 12 of 12 Posts
I did the oil and rear drive today and the rear drive only took about 4 Oz. of 80W is that all it takes after a drain ?
If it is will change it with every oil change.
It should take 230 mL, which is just about 8 ounces.
Many of us change the rear drive fluid at every oil change.
Yikes!
The rear drives takes 230 ml or almost 8 Oz.
OK will recheck and Make sure I have 8 Oz. in there
old eyes !!!
The easy way...
As mentioned in the Tech Manual... or, somewhere, just fill the FD to the bottom of the threads in the filler hole. And, thats a lot easier than all the measuring. :D
True...but measuring prevents those fun little over-fill spills.
old eyes and publicly educated brain.
old eyes !!!
Well rechecked this morning and It was 8 Oz. looked at the 32 oz. bottle and it is right at 26 oZ.
Must of done some public school math last evening when I checked :eek:
Check that public school math yet again. :D 32-26=6 You seem to be still 2 oz. low.
Typo this time
24 oz. not 26 a typo :D
Or you could do this and not worry about Joe's overfill issue either. BTW, this came out of the HOW also.
1 - 12 of 12 Posts
