My 2001 LT has a stubborn brake light that stays on.
I have pulled the tupperware and fuel tank off. Found the relay for the brake light, verified it was operational. With the relay out, the brake light went out. Put it back in, same problem. The front brake switch, rear brake switch and clutch lever all "Click" when operated.
I realize a "Click" only indicates the internal actuator is moving but will not indicate a stuck set of contacts.
The Clymer guide for this model suggests unhooking the wire connectors for the above mentioned controls in the electrical connections box under the tank to check continuity and function of the switches.
So far have been unable to trace the wires back to any connectors. What a birds nest in there.
Any ideas on where I might find these elusive connectors?
