I had a critical failure on two brake lines on my 1999 K1200LT, so I figured it was time to spend the cash and replace them with Speigler's. A little daunting, as this was my first time tearing the bike down that far (Just got it in October). So parked it on the back porch, stripped it down, swapped lines. No problem. Also flushed all the old brake fluid out of the system while I was at it. Bled the ABS unit first, then my front lines, then my rear (both bleeder screws). Got everything back together and it was time for a test drive. Drove around the block first (about 3/4 mile) and noticed that as soon as I hit my rear brake it was super stiff. it also felt like the bike was using more power than normal to stay at speed. when I got back to the house the rear break was really hot, and you could tell it was sticking. When I crack the bleeder screw on the rear caliper it frees up, but sticks compressed again when I push the rear break pedal. It was working great before I swapped the lines.
Hopefully someone has an idea to help.
David
David
