Looking to change the rear brake fluid for my '99 LT. In the manual it says to remove right-hand battery cover.
Could someone please explain where this is on the bike. I have not had the bike apart and am trying to find where the rear brake fluid reservoir is.
G'day Colin,
The reservoir is a bit difficult to see and get to... It is located just forward of the rear pannier and from recollection, I think that I had to remove the passenger seat (at the very least lift the riders seat) to get to it. It is a bit awkward to get the top off without stripping tupperware but do-able...
HTH
Discussion Starter · #3 ·
Thanks Ian. Is that the left or right pannier? and what does the sucker look like?
Just topped up my rear reservoir today. It was at MIN although pads still have 6 mm each.
I used s drinking straw with my thumb over the end to transfer small amounts into the reservoir without spilling. There is probably a more elegant way but this seemed to work for the small amount that I had to add.
Hi I will try to put a picture of what i use to fill the rear master cylinder . it is a cheep mustard bottle with a peace of O2 hose on it ...patric ...
P.S. well that didn't work , I take a snap shot tomorrow ...
Hi ,here is Try # two for a picture of my rear brake fluid filler invention...patric ...
Cool ideas - somebody posted a few months ago about using a large syringe to fill the reservoir. Also, if I recall, somebody a few years ago talked about drilling a small hole in the tupperware so that they could view the level in the rear reservoir without removing the tupperware or the rear seat.
