1 - 14 of 14 Posts
Wrestle! Not really. Light heat from behind, then try to get a string under the strip and bag and work your way back. It's really easy on some, and a longer project on others. I've done two-one was easy, the other quite hard. Take your time-another way to 'learn' your bike. I used 3M tape to install the new ones-after 150K miles, they are still on.
Keep us updated on your weekend project!
Sturdy dental floss will cut the foam tape a bit better than string.
Are the newer ones with LEDs held on the same way and are new replacements available?
They never came from the factory with LEDs. Those were after market but yes they come off the same way.
I'm surprised, Mine looks so good that I thought it came that way from the factory. One of mine is scratched are replacements available?
The guy that made them just used stock reflectors so you could pop it off and see if you can remove the LEDs and transfer them to a new reflector. I may still have my instruction sheet that has pictures, if so I'll scan them and post.
A hair dryer and fishing line
It is the chrome trim that is scratched and needs to be replaced, my led lights are fine. My bike has a few cosmetic flaws and the scratched trim is the worst. it's in pretty good shape for almost 13 years old and I already replaced the cracked ignition switch cover with a used one and if I can replace the scratched chrome I can live with the other minor flaws. :grin:
What I need to know is where can I get a replacement chrome piece? All I ever see is the used whole bag assembly and usually the chrome is scratched worse than mine.
You cab buy it new from the dealer for $153.
I thought they might not be available from the dealer any longer and I knew if they were it would be expensive. Thanks for the info I guess I had better save up and get one before they are no longer available. I just bought new Metzelers for it and fork seals and it needs a couple of other things before I start on cosmetic things. The ignition switch cover I found used so it didn't cost much but I haven't had any luck finding the chrome piece used.
Where are after market moldings with LEDs available from?
The guy that made them has since closed up his shop. It was "Rider West". It no longer shows up on a google search. He basically used stock reflectors and glued red LEDs to the back and included wiring. Got to remember that the LT went out of production over 10 years ago and most aftermarket stuff has dried up.
It is too bad as Lots of new owners of used LTs can afford aftermarket stuff better now that the bike is more affordable.
1 - 14 of 14 Posts
