It's part #33117722890
Its a ring seal that goes on the driveshaft side of the axle. You know that ring area that's around the hole on the rear shaft.
BMW direction has you drilling a hole in it and pulling it out somehow with what seems like a slide dent puller.
Thanks for any help
Mike
I remember seeing a video on this somewhere.
That is the 60mm seal. You remove the black cover, don't chew it up and the snap ring underneath. Then find a shaft seal puller like this:
Or, find a small sheet metal screw and the proper drill bit for it to be snug. Drill the seal kind of close to the outer edge but only just through, don't push and get into the bearing underneath at all. Put the screws in, two 180* apart and pull the seal out with the screws. The warning is you can trash the bearing if you are not really careful. Clean up and tap in a new seal that has a little oil on the edge to help it slip in.
Reactions: Patric
I had to put that seal in my 2010 R1200GSA 5 -6 years ago. All I remember is doing a little drilling & pulling it out with a slide hammer...I think... It went easy enough ..
