1 - 9 of 9 Posts
Ever since buying my '99 KLT about a year and a half ago I have had problems with intermittent static or interference through the sound system. I think the radio was picking up EM interference because it often happened when riding near or under power lines. I tried the "fix" suggested in several threads, which was to clean all the radio wiring connections and add dielectric grease. I tried that in April while I had the tupperware off to install some farkles; there was no visible corrosion, but I greased the connections anyway. No effect. I realized later that I had missed the connections inside the stingray and resolved to clean those the next time I had the bike apart.
Last weekend I stripped the bodywork to route an Ice Link dock connector cable to the oddments box. I disassembled the stingray and checked and cleaned the connectors to the radio. Again, no visible corrosion but I sprayed the connections with ProGold.
The other cause of EM interference I had read about on this forum was "leaky" capacitors inside the radio itself. I was thinking about this while I had the radio "box" in my hands. I wondered if there was a way to shield it.
I pulled out a roll of aluminum foil and wrapped the radio box a couple of times before re-assembling the stingray. I figured it couldn't hurt.
For the last week, I have had zero static. It is completely gone.
I suppose it's possible that one of the connections that I checked was not making good contact, and fiddling with it or spraying it with ProGold was what fixed the problem. I think it was the foil that did the trick. I don't really care, of course, as long as the static is gone.
If anyone is having this problem, you may want to try this.
I think you're onto somethin.......you know ever since I started to wear my aluminum foil cap to shield my head from cosmic rays...my headaches have stopped.
OK ...come on now .....I'm just kiddin you...put down the gun now:)
I actually think it is the guys with the straight jacket and the padded van. ;) :)
Good idea. A lot of guitar players use aluminum foil under the pick guards and to line the holes routed in the back of the guitar to eliminate hum.
Ah,
That's why Grif is lucid these days!
1 - 9 of 9 Posts
