1 - 3 of 3 Posts
I read on this site the other day that someone was using a 30A Radio Shack relay that was only temp rated to 85* F.
They now have a 40A SPST relay with much better operating environment specs. -40*F to +257* F should cover MOST of CONUS. Specs provided below for your review.
Loren
Dimensions
Product Height
0.9 inches
Product Width
1.1 inches
Product Depth
1.1 inches
General Features
Model
275-001
Product Type
SPST
Enclosure Color
Black
Miscellaneous Features
Min Operating Temperature -40 Fahrenheit
Max Operating Temperature
257 Fahrenheit
Humidity Range Operating up to 95%
Supported Languages
English
Mounting Kit
Mounting bracket included
#per pack 1
Power Features
Voltage Required
12VDC
Me-thinks it was Celsius
I do not know of the post you are referring to, but I find it hard to believe the 85F rating of the original part (because I am in the business) - there are no general purpose parts rated that low - it's below human body temperature.
Most likely, the rating of the original relay was 85C - which is a typical industrial grade range (equals 185F).
Now, the new part you are referring to is indeed better. However, bear in mind that the specs on Radio Shack components have to be taken with a lot of skepticism - they are often unbranded seconds.
Bottom line, either part will work in our motorcycling installations as long as you are not pulling more than 20A to have some margin. 20A is 240W, not likely that we have such loads - even the aftermarket horns pull less.
No need for the worry beads.
Re: Me-thinks it was Celsius
Don't know what temp scale he was referring to. Farenheit, Celsius, Kelvin, etc. He was just concerned about the temp rating of what he had. It would make sense that the rating was in celsius as an 85* F relay would be pretty worthless!
1 - 3 of 3 Posts
