Yesterday on the way to work I shut the bike off to fuel. When I restarted the bike I got no response from the CD/Radio, got a "No Radio" message. Then eventually the radio window went dark. When I got home I read through the HOW and found threads with similar symptoms. Took the HOW advice and disconnected the battery to attempt a reset. While I had it disconnected I removed the battery and took Dick's advice. I cleaned the battery, topped off the cells with distiiled water and put the charger on it. When all done and reassembled tested the radio and all is well again. Anybody figure out why this works. How often has it occured to the same person? Great info in the HOW thanks.
