1 - 20 of 29 Posts
Well my 2003 LT radio with cd player stopped playing sound through my rear speakers. I followed the advice on this forum and nothing worked (I unplugged the battery overnight, I hit the sting ray, I checked the barrel connectors, I sprayed Wd-40 in the connectors, I tested the battery, (12.2 volts engine off, 13.3 volts engine running) Nothing worked.
So I decided to call Becker of North America and learned a few things about the radio in the LT. There are 3 models.
  1. Radio with Tape Player
  2. Radio with CD 2003 and older
  3. 2005 and newer Radio with CD.
The units are not interchangle. You can not install a radio with tape player in a bike that has the controls for radio with CD and you cannot use a 2005 or newer Radio with a 2003 bike.
Becker can repair a radio with Tape Player (they still have the parts), but they can-not repair a 2003 or older radio with CD. (they do not have any more parts) The only option is to buy a new one from BMW. This is because BMW ordered a certain number of radios to be built and a certain amount of spare parts to be stocked. Becker does not have any more parts for the radio with cd, 2003 and earlier and therefore cannot repair them. When the BMW runs out of the replacement 2003 CD radios, there will not any other radios available.
I asked if changing a battery or un-hooking the battery might help the unit to reset itself and the answer was NO. If the AMP is failing, then it is failing.
So while I had him on the phone, I figured I would see if he had any news on the next generation LT. I asked if they were working on a new radio for the next generation LT and he said he was not aware of anything new that they were working on for BMW. :(
So now I guess I have to live with only 2 speakers or take the plunge and spend between $550 and $750 for a new radio...
Any idea when will the new LT be out??? I dont want to start dumping money into a bike that I plan on trading in as soon as the next generation is out.
Bizarre...I bought a single CD for the oddments box and removed my tape player on my 00 LT, plugged right in and works fine...
Your source at Becker is incorrect. The Tape and CD models from '99 through '04 are indeed interchangeable. You do, however, have to install an AM/FM antenna adapter to go from a tape model to a cd model, but the controls and buttons work with either. I did the conversion about 3 years ago on my '99 and she works like a champ.
Bill Edwards
'99 K1200LT
'75 R75/6
+1 for Bill. I did mine last year. Went to a cassette from CD. No Problems.
Just the adaptor for the antenna.
You can pick those up at Bestbuy.
Zeke
The date is around August 2003 when they changed to an incompatible model. There are two part numbers which are not interchangeable as I found to my cost. I think the digital dash models all had the later part number CD head.
Ajlelectronics said:
To adapt the aerial (antennae is what ants have on their heads) to the different connector type.
I didn't see any smilies in your post so can I assume this is a criticism :confused:rather than a joke on your part? :bmw: Most web etiquette faqs recommend the inclusion of smilies or other forms of clarification so that others can tell mirthful jibes from boorish snobbery. Hopefully you just forgot. :bmw:
The majority of members on this forum speak and write in American English not British English. There are many differences between them not only in spelling but also in terminology; for example trunk vs boot, bumper vs fender, lorry vs truck and in this case antenna vs aerial. Of course many Americans don't know much more about American English then they do British English. It's a result of too many failed or failing educational systems in this country. :)
For your reference here is American Merriam-Webster definition of the word "antenna".
Main Entry : an·ten·na
Pronunciation: \an-ˈte-nə\
Function : noun Inflected Form(s):plural an·ten·nae \-(ˌ)nē\ or an·ten·nas
Etymology : Medieval Latin, from Latin, sail yard Date:1646
1 plural an·ten·nae : one of a pair of slender movable segmented sensory organs on the head of insects, myriapods, and crustaceans — see insect illustration
2 : a usually metallic device (as a rod or wire) for radiating or receiving radio waves
3 antennae plural : a special sensitivity or receptiveness <his political antennae proved to be shrewder than ever — Erich Segal>
:D With enough interaction most people eventually come to the realization that America and Great Britain are two countries separated by a common language. :D
Miles of Smiles
Re: Radio Repair Update, interchange amps
Assuming you have both, i.e. a cassette type radio and the CD type radio are the amps interchangeable ?
Maybe you should get back into bed and climb out the correct side again? If you care to review my extensive posts, you will note that there have been no agressive or deliberately rude posts from me. But then most English folk have a sense of humour (note the correct spelling).
They are integral units, so there is nothing to change between them. How about replacing it with an aftermarket radio? There are adapters available to enable the use of the handlebar controls, but I don't think you can keep the display function.
I would think adapters will be available over there but in England http://www.connects2.com do a range. I use a Becker to Sony adapter so I can run a Minidisc player instead of CD.
At the moment I am experimenting with a Pure Highway DAB head.
Miles of Smiles
I'll Look into It.
Many thanks. Just recently discovered the dreaded no radio display. Haven't used the radio for over 12 months, and as the intercom works just fine, not too fussed. Ages ago (2003) bought a cassette type and after I get around to doing all the trouble shooting checks for this one ( yes, I do know them ) There remains this spare unit to cannibalize if required. Just a thought.
Thought for today.
What a lovely day, think I'll go for a ride. :)
Now, now Gentlemen...let's get worked up at Al-Qaeda and the Taliban, not each other. :)
If it were my problem (the radio, not the etymology or linguistics), I would visit a local audio shop and see if they have any suggestions or ideas to fix or replace. Heck they might get a 3000w boomer with sub in the trunk. Hoo yeah baby. Maybe some hydraulics too..... Wait, I'm getting off track.... : )
But a stereo shop might be able to help.
Randy
Is this an Oooops moment here, :rotf: please note the smiley.
So now I guess I have to live with only 2 speakers or take the plunge and spend between $550 and $750 for a new radio... QUOTE]
I see entire "stingray" assemblies on eBay, as well as radio units, for sale quite regularly. I bet you can pick up a used replacement radio from a wrecked bike and save lots of bucks.
:crazy: I can see that the communication failures continue unabated. :) I actually slept quite nicely and did get up on the correct side of the bed, thank you very much for your concern. :)
All I did was ask you a question and attempt to explain, in a an unsuccessfully humourous fashion, how you could prevent people misinterpreting what you are now inferring is your form of language "humour". That's what the confused emoticon and the question mark in the first sentence were for. I never stated you were rude or aggressive and I don't know you well enough to have an opinion.
Obviously the humour of our respective countries is as different as our common language. :histerica Correcting someones grammar is considered by many here in the colonies to be rude. Hell a lot of colonials think any kind of criticism is rude. Down with the colonials! You can pretty much expect any viewpoint on a web forum or mail list to be challenged by one or many opposing ones. Anonymity seems to impede the higher social graces. :)
:think: Nope, just call me mister inconsiderate if you want but I can't read minds and I do not care to review the posting history of every person who posts comments on a forum in order figure out if they are joking or being critical. If I am in doubt I will ask. If a person doesn't spend the effort to effectively communicate the meaning or emotions behind their written words then why should the readers be expected to put any effort into divining the meaning? It's no big deal and it happens to everyone from time to time. We aren't thinking, were tired, were in a hurry and we certainly aren't perfect, especially me. Usually nobody thinks anything much about it but sometimes someone does.
:D :) If I were a rude person and really thought that you were being a jerk I would have sent you a PM. It would either contain directions for where the the King's English could be more appropriately deposited or something slightly more obtuse. Something like the American Revolutionary War is over and you lost, so get over it. :) :D (Note: Emoticons indicate an attempt at humour)
But I am not a rude person and I meant no disrespect. If we should ever be fortunate enough to meet and the Scotsmen and Irishmen in my family tree are not an impediment ;). I would be proud to pretend to laugh at your jokes and buy you a beer :beer:,
or perhaps that should be a pint? :toast: :bmw:
248 posts are extensive? :rotf: Just kidding Andy.
You're just showing off, you with your 4000 + posts :histerica
We want quality not quantity :rotf: :histerica
(Please note I'm laughing my bloody head off as I type this!)
1 - 20 of 29 Posts
