beemer100 said:
I noticed while riding that the temp guage was creeping to the red area and hitting higher than before. It hit the white line that begins the edge of the red area with no fans spinning. I let it idle in my garage and no fans. They would normally come on about 3/4 hot.
Neither fan comes on and wonder what steps I need to take to make sure they work right.
Any suggestions?
Thanks.
James
James - check this fuse list and notice that each fan has it's own fuse, in the left fuse box - plus there is a fan relay fuse in the right side box also. You prolly know that the fuse boxes are under the passenger seat, but access to 'em can be gained by lifting the driver's seat. Good luck.
Right-side fuse box (brake levers side).
1. Brake light switch, fuel level warning
lamp, fan relay, instrument cluster,
windshield adjustment switch, computer 4 amp
2. Parking light front and rear 4 amp
3. Horn, brake light, alarm system 15 amp
4. Motronic, fuel pump, diagnosis 15 amp
Center fuse box.
5. Instrument cluster, computer 4 amp
6. Heated grips switch 4 amp
7. Windshield adjusting relay, sockets 1&2 15 amp
8. Radio, reading lamp, topcase interior light
power socket 15 amp
Left-side fuse box (clutch side).
9. Right cooling fan 4 amp
10. Left cooling fan 4 amp
11. Seat heating 15 amp
12. Cruise control 15 amp
