R1250RT Alarm system question
2783 Views 6 Replies 4 Participants Last post by  Capt Sisko
I'm trying to figure out how the alarm system works on my 2019 R1250RT (Select package)
The owner's manual doesn't correspond to the settings on the bike.
The manual (p.90) shows all kinds of available settings for the alarm system, but on the bike I only have one : Sensor On or Off ? (Which is not mentioned in the manual???)
I have no idea if the DWA is activated or not. No sound or flashing lights, no indications on the display.
When you choose Settings/Vehicle /Alarm system/ there are 4 options. Sensor is the 4th. If when you chose "Alarm system" all that you see is Sensor, use the wonder wheel to scroll up and the other 3 options should appear.
Either that or FIIK.
Ian
Thank you so much.
I feel a little stupid also for not noticing the small arrow pointing up :eek:
Thank you so much.
I feel a little . . . . . . . :eek:
It can happen to anyone . . . . ask me how I know :wink:
In my experience instructions only make sense once you've worked out how to do it anyway.
Ian
  • Haha
Reactions: 1
Thank you so much.
Hi Dann,
I've just joined the blimey, 'how did I miss that' club after spent an annoying day thinking this is stupid, why is there only a switch the sensors off (once) option and with bike re-arming itself every time I switched the ignition off whilst I was doing a bit of work on it. Thank goodness for the internet I say.
