Hi all, I'm new here. This site was reccomended to me by a gentleman helping me diagnose this issue on another forum, he suggested that I run it by you gents.
Here's the story. A friend brought me his 2006 R1200RT with 76k miles because it the dealer told him it needed a final drive, among other things. From time to time, his brake failure light would blink, the red triangle would blink and the speedo would stop working. He took it to a dealer and they told him they found several faults. Low fluid level, low voltage, and low rear pads. The tech also wrote in the comments section that the ABS pump may need replaced if the above doesn't fix the codes. When removing the rear wheel, the tech also noticed a large amount of play in the final drive.
So, for reasons I won't go into to, my friend doesn't trust this dealer so he brought the bike to me. Final drive had tons of play, so I confirmed what the dealer told him. I replaced the final drive with a known good unit from a 2005 1200GS, George from Beemer Über Alles advised me that the final drive would work other than the gearing being lower. A visual inspection seems to confirm this, as both final drives appear to have the same indicator ring when viewed and measured through the sensor hole.
So new final drive installed, new brake pads, still have the failure light and triangle blinking. Except now it does it all the time and not just sometimes. (battery is 100% charged) So, I stripped the bike, and did a complete brake fluid flush and bleed according to the instructions found in this article http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf
Now, I don't have a red triangle anymore, but the failure light is still blinking, and the speedo doesn't work.
I'm trying to eliminate as many possibilities as I can before telling this guy to order a new ABS pump.
Any ideas? Thanks in advance!
