A Very Good Question...
The chart I have attached says that the headlight including the High Beam Indicator are UNFUSED!
If they are the BMW type fuse with exposed wire across the top, you will be able to see if the wire has burned in two... If they are standard American type fuses, you will probably have to pull each one to see if any are blown.
I suppose it could be the load shed relay... because it turns off everything that isn't necessary when you start your bike... perhaps it isn't turning it back on after the bike is started?
I also included the starter circuit... just cause it was handy and may help diagnose your problem. The electrical schematic is also attached in PDF Form...
Good Luck, and Let us know what you find out... it may help others with the same problem...
