Parting out my 1200 lt had a fuel rail fire want to remove the front fork wheel, tampter, caliper everything is off now the fork has a nut with what look like am allen in the middle how do I remove this is rthe allen a lock nut tried but no success
Are you referring to the collar nut on the ball joint (#14)?
If so you need to heat it and also a special tool would help. Attached are a couple pages from the manual, if I'm on the wrong place disregard.
After re-reading your post I think I was thinking of the wrong place, now I'm thinking you are dealing with #2 :
If so these pages (see attached) will probably be of more use to you, still basically the same issue.
so I should place an allen wrench then with a wrench losen it up I think am going to have to heat it
Definitely heat, just make sure you don't overheat.
