So my 2005 RT, purchased used a few years ago, came with these lights. I'd like to get an identical replacement set, but unable to determine the brand of the lights. I'm aware that there are much brighter and better lights available out there, but I personally prefer the looks of these, and how they blend with the bike's aesthetics quite nicely. I don't expect a lot from fork mounted lighting in terms of output...down this low, their primary functions are: providing a larger lighting footprint for oncoming vehicles to see, and a slight bit of extra illumination of the road surface. These have performed those functions satisfactorily, until one bulb burned out recently. It appears as though the bulbs are not designed to be accessible for replacement. Anyone familiar with these lights?
173202
173203
Moto Lights, Caliper mount. There is a U shaped pin wrench that is used to remove the lens ring. Look here
Reactions: kbob12
Discussion Starter · #3 ·
John, thank you so much for that...it was frustrating not being able to locate the information. Truly amazed that someone responded so quickly with the helpful info...Ordered the removal wrench, and will see what kind of bulbs are in there. Looking at their website, it appears as though the bulb can be purchased through them as well, and if I'm understanding it correctly, the bulb is fairly large, almost the size of the housing, and has 2 pins on the rear to connect to the wiring. When the wrench arrives, I'll remove the housing and check what I have. May be a good time to upgrade to their LED bulb too... Thank you so much for the help!!
They are just 12V MR-16 bulbs (landscape lighting). You can buy from Motolight or get at the big Box stores (not going to find a spot version there) or on the internet at a bulb site.
Reactions: kbob12
Discussion Starter · #5 ·
That is actually even more helpful, might save money that way...When you say "won't find a spot version" at the big box stores...I'm assuming the stock version is a spot, meaning, a more straight-focused beam, basically?
The Motolight bulbs are 8 degree beam for the 35 watt and 12 degree for the 50 watt. Most of the ones at the Big Box are floods. They still work good for conspicuity but they are not good for extra light at night. Some of the bulb web sites have tighter beam widths for a reasonable price. Personally I run one clear and one amber just to get noticed. Search on MR-16 and spend a day looking at them.
Reactions: rhansen and kbob12
John,
I have clear now, was thinking of replacing with amber. Do you run an amber lens, or an amber bulb? Do you have an opinion on bulb power, degree, LEDs, etc? Interested in your recommendations (I currently have older, maybe original?, white bulbs in them)
Thanks!
Steve
So my 2005 RT, purchased used a few years ago, came with these lights. I'd like to get an identical replacement set, but unable to determine the brand of the lights. I'm aware that there are much brighter and better lights available out there, but I personally prefer the looks of these, and how they blend with the bike's aesthetics quite nicely. I don't expect a lot from fork mounted lighting in terms of output...down this low, their primary functions are: providing a larger lighting footprint for oncoming vehicles to see, and a slight bit of extra illumination of the road surface. These have performed those functions satisfactorily, until one bulb burned out recently. It appears as though the bulbs are not designed to be accessible for replacement. Anyone familiar with these lights? View attachment 173202 View attachment 173203 View attachment 173202 View attachment 173202 View attachment 173203
MOTO LIGHTS
Way to go, Brett! Right on point!😂🤣😇
How's the recovery going? Lots of happy meds, I bet. Be sure and keep that shoulder/arm immobilized for as long as the doc says. PT will start soon enough.
John,
Thanks!
Steve
I am running an Amber bulb on one side, it has an Amber lens built in to the bulb compared to my Denali lights where I added a plastic lens to get the Amber color. I am using 50 watt incandescent just because they are still working but I would eventually go LED when these burn out. I had bought some incandescents from a bulb web site several years ago and they seem to last forever and I still have spares!
