1 - 2 of 2 Posts
Many have noted that they are not only drilling a weep hole in the area where the clutch slave cylinder is located, but they are also drilling a 2nd weep hole in the lower part of the tranny case (clutch housing). The purpose of this 2nd hole is to drain fluid if your rear output shaft seal fails. While there are plenty of write-ups about the clutch slave cylinder weep hole, I can't find anything on this other hole. Where are folks drilling this other hole? Any pictures? Can it be done non-invasively?...or does it require the removal of some parts?...like perhaps the center stand, etc? Any advice is much apprecaited.
Regards,
Toolman
Discussion Starter #2
Disregard....I found some pics in another post. I didn't search well enough at first. I would have simply deleted my post, but the system wouldn't let me....even though there weren't any replies to it. Sorry.
1 - 2 of 2 Posts
