It runs! Soooo many things had to go right for that to happen I really can't believe it. Only discovered one slight leak on a fuel line clamp so used an old boating safety practice and double clamped. Works perfectly and no leaks. Idles a bit high - 1100 or so, so I expect the TPS needs to be reset, but otherwise couldn't be happier. Now I just need to figure out where all those screws go to reassemble the tupperware! Remaining on the list - change one taillight bulb, replace the tires, check and change the brake pads if needed, install the new (used) powered centerstand. All of which do not prevent me from riding and getting it inspected. Thanks to all for guidance and foremost to Kirk Johnson for the videos, without which this never would have happened.
