2005 K1200LT:
After battery running down on bike over the winter and fob battery replacement, I can't get the bike to recognize either of 2 fobs.
When I follow the directions in book SUPPLEMENTARY RIDER'S MANUAL (US-MODEL) ANTI-THEFT ALARM SYSTEM DWA 5, Chapter 6 page 26 & 27, It mostly works. The 2 beep acknowledgement tone occurs after ALL digits have been selected instead when you switch on the ignition after each digit as stated, but I do get the confirmation beeps. This should allow me to register my fobs.
Moving on to page 28, it says
to "Press and hold down buttons 1 and 2 which will cause LED #3 to flash" YES
Then "LED stops flashing after 10 seconds" YES
"Release buttons I and 2" and the LED will stay ON. YES
"Press button 1 or 2 and 1x alarm, LED off" NO!!!!
The fob blinks a couple of times and goes out but the bike never responds. Neither fob causes a response from the bike. In 30 seconds the unit times out and chirps 3 times. The alarm light is supposed to flash the number of fobs registered, but that must be 0.
I have done the synchronizing routine mentioned on page 30 and the routine for replacing the battery on page 30 & 32.
These fobs were registered with this machine a couple of years ago.
As I remember, the programing wire is non-applicable on the 2005 machines and are programmed via the fobs.
Anyone have instructions that are different than the ones I have?
