New to the forum I have a 2013 k1600gtl love the bike noticed today that windshield does not return to the down position when I shut the bike off? Was wondering if any one else had this issue ?
Hello Paul
Can you raise or lower the screen with the switch while the bike is on? This happened in the past on RT, the pivot pins get seized and you need to lube them, remove them if possible, clean and light coat of synthetic grease, a drop or two of lubricating oil once in a while to prevent seizing again
Tony
Sent from my SM-N960U1 using Tapatalk
Discussion Starter · #3 ·
Hi Tony it works fine with the switch full range of motion it just doesn't return to the down position when I turn off the bike.
Paul I moved this thread to the K1600 area you may get better responses here for help.
Does your K16 have a GPS ? If the lid is popped up the screen will stay in the up position . Look over at the sister website K1600 forum . There is tons of info on everything K1600
