1 - 18 of 18 Posts
I was disappointed to see that the power outlet locations on the 2009 LT seem to be optimized for heated clothing. I would like to be able to charge my cell phone, and having an outlet by my left foot, or by the passenger armrest do me no good.
I would love to somehow have a power outlet in the center console. Is there any way to do that?
I've heard that someone has installed a plug in the top case. I don't remember who and a search might not work out so well. I'm sure somebody will be along shortly that has the info you're looking for.
You can have a Power-let???? installed just about anywhere you want as long as it will fit below the body work.
Some folks run a power lead to the tank bag. You can then plug in your cell phone or any other device and keep it safe in the tank bag. Also, some tank bags are already set up for power connection.
That's what we use. Check out RKA's In-Charge series of tank bags. A single power cable runs from the battery into the tank bag. From there, you can do whatever you want. We charge our cell phone and power the GPS with it.
Check out www.aerostich.com. Their latest catalog (which I wish they would stop sending because it has too much in it that I want, but don't need) has several "all-weather power outlets."
Their latest catalog, page 21 has two, along with other accessories. One is $15 the other $20.00.
I'm sure their web site list more.
I mounted a power socket on the right side, just under the seat. Then used fused power from the battery
Yeah, the outlet locations make no sense to me. For anything; why would I plug heated clothing in by my foot??
Anyway, installing an outlet is nothing tricky. Either a Powerlet or regular cigar lighter. There are lots of options available at automotive stores for the standard lighter type. One that could be good for what you want is taking a lighter extension cord and putting the end inside the box in the Stingray, then running it direct to the battery (with a fuse of course).
I have my tank bag powered and thats also where my controller is for my heated clothes.
I put mine in the top case,
Like this? :) you can get a power "source" behind the left rear speaker
under ten bucks at the auto parts store,
notched the plastic put a split rubber hose around it
and added a switch even though it only has power when the bike is running.
I use the rear left outlet, throw the cell in the trunk and use the blue tooth in helmet. If you need another outlet you can buy a dual plug in and use one outlet for cell and the other for accessories. Am I missing something?
Discussion Starter #12
Those look really cool. However, it looks to me like they would obscure the built-in GPS. Does anyone have one of these that can confirm/deny?
I have installed an outlet in the oddments box for my iPod, straight from the battery via a fuse and one in the topcase like Silver Buffalo. Neither are difficult to do,
I am using an RKA tank bag with the factory gps mount and a Zumo 550 on an '08. No problems here. RKA is good stuff!
I can't help you with that one. My GPS is on a RAM mount on the front of the RKA tank bag. The GPS obscures the the audio system buttons, however. Not a big deal, as those can be memorized or you can just look over or around the GPS if you need something.
I installed outlets in the trunk kind of like Silver Buffalos, I have a cigarette lighter on the left dash where the BC display is on pre-2005s (mine is a 2005 and I just have a blank there), and I have a USB port installed inside the oddments box for my cell phone...with a connector into the factory radio/intercom.
Almost a year ago, the OEM battery in my '08 failed. I bought Costco's PSX power station for $65. I took it apart for the 18AH battery which fit nicely and has served perfectly for almost a year. Here's a description and picture from a different source
http://itemsave.com/powerstation-psx-multipurpose-vehicle-jumpstarter-w-air-pump-p-146.html
This week during the bike's 24K service, I installed the rest of the PSX parts on the bike, including the 12v socket. I chose the area near the headlight adjust knob because its convenient to my UMPC (computer) and there is plenty of space behind that panel. I connected it to the unused power pigtail (near the fuel pump) so that it would be properly fused.
I also mounted the air pump and pressure gage from the PSX. By the way, the pump is really a good one. Much better than Harbor Freight's smallest. I opened then ends of the the long ago removed fuel cannister to use it's shell. The pump fits inside and is just cable tied in place with a high density foam spacer. The pressure gage fits nicely in the space just behind the battery and doesn't need to be mounted.
Power comes from the same fused power pigtail as the outlet but goes through a small switch (see photo).
I used flexible drip irrigation tubing and barbed fittings to connect the pump to the gauge and tire fitting. It provides plenty of volume and enough hose to reach the front tire takes no extra space under the seat. The hose tucks nicely under the left side panel. I put a cable tie over each hose end and fitting for a little extra bite. I tested the pressure to 100lbs for over and hour with no problems or pressure loss. I'm a little concerned with everything staying sealed on a hot day, but that will have to wait for a hot day. It's really sweet to be able to add air, flip off the switch when it's correct, and not have to mess with a separate gauge or check it twice.
If I didn't already have a battery tender, the PSX comes with a nice one and includes a volt meter. It would just need a box. They supply a cable with dual 2 plugs that could charge the bike through the newly installed socket.
Has any one used SLIME tire fix? Does it work? I plan to carry a 18oz tube of it since I now have air on board. There is a spot between the front forks to carry it.
I put a single outlet in my top case, but it is like a pig-tail and has a fair amount of cord left on it. I took power from the rear BMW plug, passed the wires into the top case, under the liner, put in a connector, so removal of the top case is not affected other than unplugging two additional wires, put a small slit in the liner and done. This way I can charge a phone, ipod etc and with the extra lenth of the wire, can make sure it the item I want is always on top and can be moved out of the way. When not in use, I push the wire back through the liner and all that is left is the plug. Simple add on for $5.
Also, depending on the year of your bike, the rear BMW outlet stays hot unless the wheel is locked. If you're running something in the trunk and don't want it running the battery down, just lock the wheel.
1 - 18 of 18 Posts
