No power at the outlet. I checked the fuse blocks but can't find a blown fuse . I have the LT Manual on CD but don't see a wiring diagram. Help!
The Villages, FL
Is the key on? The power outlet is controlled by the key.
Kevin, have you had the top box off the bike recently or disconnected the the two wire bundles to the box? Maybe plug is not secure or a bent pin.
Kevin, the fuse for the top box power plug is the #8 (bottom) fuse on the center (B) fuse block. This fuse also covers the interior light in the top box so if the light works it is not the fuse.
IIRC, if the key is in the 'R' position and not OFF, this port should be live. Sounds like you've thoroughly tested that though. The next step is to ensure that the fuse is not blown. The easiest way to check this is to see if the light is working inside the top case. If it comes on, then the fuse is obviously OK. (If your LT is a pre-'05, we're talking about fuse #8 here. Bottom fuse in the middle fuse block.) Of course, if the light does work in the top case, we're looking at a few more possibilities.
  1. A bent pin in the electrical barrel-connector of the top-case. HIGHLY unlikely.
  2. A broken wire to the Powerlet port. Not very likely.
  3. Corrosion inside the Powerlet port. A better possibility.
  4. Ensure the device that you're using to test the port works properly.
