I never had a problem with the Montauk brakes for 12 years and 60,000 miles. Flushed the system regularly according to the BMW maintenance schedule. Had both wheel circuits and the control circuit flushed two weeks ago, and that's when the warning light stayed on and the other light started blinking fast. The error code indicated that a sensor thought the pressure was too high, which seems ridiculous since the bike was cold and all three brake circuits had just been flushed.
Interestingly, after the bike warms up, the servo starts to work anyway, and if I turn it off and re-start it, the warning light turns off after a few seconds, the blinking light blinks slowly and turns off when I start moving, and the servo works. Normal behavior, in other words. I think there are seven sensors, but I don't know if they are replaceable, and I am not a wrencher.
My mechanic says that the brakes are just as strong or stronger when the servo and ABS are eliminated/bypassed. If I find that's true on the Montauk, I might look into doing the same thing on the LT. I think I'd like the brakes to have the same feel on both bikes, no servo and not integrated. I'd keep the ABS if I could, but I doubt that's possible.
I believe the Montauk speedometer doesn't work without the ABS sensor, and I assume the same is true on the 2009 LT. The RH kit takes care of that. How tricky is the DIY bypass surgery on the LT?
