Ok, so the most recent problem is this....
The bike was taken apart to take care of multiple servicing including flushing of all systems.
From what I understand, to refill the coolant system, it's a bear because the filler port is horizontal and not verticle and there's a potential for some leaking and being deposited on top of the engine where it's similar to a bowl and can retain some of the seeped coolant. If this is not washed off, it can spray on the bike for the first several miles. Hearing this, when I experienced coolant spraying on the left side of the bike on my foot, leg, and bike, I thought well it just takes time for it to all blow off. This went on for several days in differing intensities and then the heat sensor light came on the dashboard. I was in 32 degree weather and only had 8 - 9 minutes to get home so I took a chance. The temperature guage never went above half so I thought I'd be ok. I didn't see any steam, and didn't have any steam when I parked it so I was hoping I didn't do any damage.
Did I?
Is this spray from the residue on the top of the engine from filling?
Today I checked the overflow\back up the reservoir and found it to be empty.
Was there a possible bubble in the coolant system which could have worked its way up and then drained the reservoir? Was it big enough a bubble to cause the bike to overheat?
Today I got home and filled up the overflow\back up the reservoir to just a smidge over the max line. I took the bottles of antifreeze and put them in the saddlebag so that when it sucked out of the reservoir, I could just add more. I started out and about ten minutes into the ride the light came on. I pulled over and shut it off. I took out the antifreeze and went to fill up the reservoir back to the line maybe thinking it needed more. I poured maybe a quarter or less into the reservoir (as I couldn't see exactly on the side of the road how full it was with the light) and it came right up to the top of the reservoir as if nothing got sucked out of the reservoir. I rode it back home and the light was on the whole time, but the temperature never went really above the half line (the temperature outside was 64 degrees). It makes no sense. The reservoir should have been dry. Is the thermostat not opening? Also, there was no antifreeze spraying down the side of the bike. I'm guessing either it's very low in the engine (which makes some sense), or there's no more residue on top of the engine, or if there was a leak, the leak stopped (which I doubt).
Once again did I do damage? The light came on but the gauge never went above half. No steam.
I'm not sure what's going on here.
Any thoughts anyone? Anyone ever experience any of these issues?
Woody
Did I?
Woody
