We had a tech session at my house today and did the following to my bike:
24k Service (23500 mileage)
After everyone left and the tupperware was placed on I went for a test ride and noticed the following:
1. Idle is between 650-750 RPM and wants to stall (battery light flickers) but does not
2. Clicking sound coming from valve cover area (sounds like a cylinder is not firing)
I double checked the spark plug wires and they were on correctly but both symptoms persisted. DaveDragon tried to help me over the phone with the problem and we did the following:
1. Triple checked spark plug wires
2. Pulled a single plug wire off to simulate missed cylinder to see if sound stayed, in all 4 cases sound got worse and RPMs fluctuated wildly
3. Changed all plugs back to old
4. Took off individual plug wires and hooked up loose spark plug on engine block to check spark
Pictures of *original* plugs after 5 minutes idle, plugs #1-#4:
http://picasaweb.google.com/ribbondarkness/BikePics/photo#5222320479321667522
We're working under the assumption that it is a spark issue. However this may change and the fuel system be next. I'm trying to avoid taking everything off again, but tomorrow may bring different news.
I'll be online for a bit, and your help is appreciated,
- Oil Change
- Transmission Fluid Change
- Final Drive Fluid Change
- Valve Clearance Check (all within spec)
- Spark Plug Change
- Air Filter Change
- Fuel Filter Change
- Fuel Quick Disconnects Changed to Metal
- Battery Changed (Throttle Position Sensor reset after)
