1 - 3 of 3 Posts
I have reviewed the search function, but could not find any information pertaining to this particular question. I have a 2003 LT with 70xxx miles and developed an idle problem over the past few weeks. Last week when I started the bike, instead of going to the study 1000 + or – idle the bike dropped down to 500 + or – and was very rough. After pulling away the engine stopped at the next stop sign. I restarted it, but it went to the low idle and would not continue to idle unless I held the throttle slightly open. This went on for the next 10 miles and when I arrived home it would not idle.
I thought I had some water in the fuel or may have just had some bad fuel so I put dry gas in it and the next day added 2 gallons of fresh fuel and all was well. The bike would idle at 1000 + or – and no other issue.
Last night I started it up and it went back to the 500 +or – and stalled every time I stopped for a stop light. I have ruled out a vacuum line, since it does not surge at idle and it did go back to normal for a few days with out any changes to the system. Once I pull off the engine is strong as ever in all the gears. It just will not idle.
All ideas accepted.
"stalled every time I stopped for a stop light."
"Once I pull off the engine is strong as ever in all the gears. It just will not idle. "
Throttle Position Sensor? That was my problem with my 2005 LT..Diagnosed by my local BMW svc dept..no problems since..
Jim,
We can check it with the GS 911. If it shows a fault code, you will at least know what the problem is.
1 - 3 of 3 Posts
