1 - 20 of 28 Posts
I live in Northern MI and am a little over 2hrs to the BMW dealer in Grand Rapids MI. I have a 9am appointment tomorrow for the 12k check up. I intended to ride it down in the am. Here is my problem. I went for a little ride tonight approx 10mi. I stopped at a buddies and visited for 2hrs or so. As I walked up to the bike getting ready to go home I noticed an oil puddle on the ground. I couldn't even really tell where it came from. I'm assuming the drive shaft but not sure. I decided to drive it home and after sitting for over an hour at home nothing has leaked. My question is, can I drive this the 2hrs down to the dealer? I don't really have a good trailer to haul it that far.
I wonder if one of you experts could call me and give me some idea what happened. If I shouldn't ride it I will be scrambling to find something to haul it with.
Thanks in advance,
David
231-357-3416
Praobably dumb questions, but we sometimes overlook the obvious ...
Are you sure it came from your bike? Could you have simply parked it where something else had dropped fluid?
What was it that was on the ground? engine oil? antifreeze? etc.
Did you check the bottom of the bike (and other culprit areas) for signs of leaking before you left your buddies as well as when you got home?
I'm sure it came from my bike. It leaked down and was on the tire. It was an pinkish oily substance. I'm sure it wasn't antifreeze. I checked it all over when I got home and nothing seems to be leaking. I'm embarrassed to say I don't even know what the culprit areas are.
Cat Herder
Leaked on the *REAR* tire?
There is nothing you can make worse. I'd say start riding, but make sure you'll have the whole day off and a transport back because you aint going back on your bike.
Before I took it for any ride, I'd check all the oil levels. It may have stopped leaking because it's bone dry. That might not work out as well as you'd hoped!
If it's pinkish, it may well be Redline. I think lots of folks (not me, I hate the stuff) use it in final drives and trannys. Just keep in mind that there's not a lot of oil in the final drive to begin with, so check it just to be sure.
Ok, this is embarrassing. That's why I was hoping that someone would call me so I wouldn't have to post this. I don't even know how to check or where to check these levels. I do know where to check the engine oil. But that is it.
I spoke to David, and it is not the engine. It is in the Final Drive region for sure. After his description to me, it sounds like it may be the rear brake line, but it also may be the final drive. "Pinkish" color kind of throws me though - a year old bike should still have clean brake fluid, IMO. There isn't any play in the FD.
I told him how to check the FD oil, and advised to do that before he rides. If he has full FD oil, he'll go to the dealer tomorrow. He has a straight highway ride.
Luckily, the "Warranty Gods" are still smiling upon him! :D
andy said:
again: rear or front tire?
I'm sorry, it's the rear tire.
I have recieved a couple of calls and now think it's the rear brake line.
Thank you so much.
David
OH NO YOU DON'T:
It's your duty to take the heat off the rest of us dumbasses for a while. Sorry, just the way it works around here :wave
Do let us know what you find though. Always a learning experience for someone.
:histerica
Roflmbaooooo
fpmlt said:
OH NO YOU DON'T:
If it was pink then it's had to believe it's brake fluid. Now the rear drive has the BMW gear oil which is now pink in color.
I would be very careful riding, if you do not have the rear bearing going then it's a bad rear drive seal. Running the rear drive dry will trash the bearing real quick. I would check the fluid level on the rear drive.
Is the final drive fill cap still in place? It's at the top of the unit. See photo.
Yes, that happened to me. At the first 6k mile service on my LT, the tech left the fill cap off; I rode 3 hours to my next destination and discovered a mess. At that time the gear oil I used was black; the Mobil synthetic I'm using is red.
I vote for rear drive fluid as the BMW synthetic is red now. Brake fluid (BMW anyway) is clear to yellowish.
The rear drives have been known to "puke" out a small amount of oil that gets trapped in the breather. Not a common item but not unheard of either.
2011 R1200RT
I still vote for the final drive; most likely a seal, hence the wheel won't show any play or harshness... for now so it is an inconclusive test.
That was my first thought too, John. Maybe the FD was just over-filled a little bit and puked. Which would be the lesser of two evils.
Discussion Starter #19
Well I just got home. It turns out that it was the final drive seal. It had nothing to do with the brakes.
Thanks again for all the help!
David
1 - 20 of 28 Posts
