I got the "running lights" (rear brake light sockets) for the front turnsignals. The directions say to tap into the pilot light's power wire to power the "parking light" side of the bulb. I can see the wires going up to the pilot light but can't really do much with them. My question is, are the pilot light's wires in a removable socket? I've looked up in there and it doesn't seem they are. If that is true it looks as if I'll have to remove one of the side panels to get at the wires well enough to do a splice in.
P.S. I already have the holes opened up for the sockets in the turn signal housings, simple work for a dremmel tool.
No offense, but it sounds like you're working way harder than you should be. Perhaps your kit is not the same one that I installed. :confused:
As for the pilot light (aka parking light), it simply just pushes up into the headlight assembly. To remove it, firmly pull down on it and it will come down and out to where you can splice into the wires and then push it back up where it belongs.
HTH
Thanks. What I got isn't a "kit", it is just 2 dual element tail lamp/turnsignal bulb holders that get put in place of the ones for the front turn signals. For this you have to open up the holes in the front T/S assemblies and make one of the aligning/locking tab slots a little bigger. Then tap into the pilot lamp's power wire for the "parking lamp" function.
I did it the same way
I did it the same way you are doing now. I didn't remove any body panels and simply tapped the power going to the parking light. You just need to reach up there and, with enough light, splice into that wire. I spliced two wires, one for each turn signal, and that was it. Obviously I had to modify the turn signal housing to allow the new bulb socket to fit, but it sounds as if you've got that handled.
Thanks. I was able to get the park lamp to come down, but I thought I was going to tear the wires out of it. That thing is really stuck up in there. I couldn't reach both hands up in there to do the splice/solider (hands are way too big). I got it done though and it looks much better at night now. Next will be the LED lights for the saddle bag reflectors and the top brake light pulsator...when they come in. I'll feel much better riding at night with the added lighting.
used these did not have to solder
Used these when I converted mine and did not have to solder at all.
Have used them for a couple of projects now and have not had a problem with them.
I don't trust those clamp on splices. They can damage the conductor in the wire and are a pain to seal up against the elements. Call me old fashioned or even anal, but I like the positive security of a good old solider joint.
understand
I have not had a problem with them Yet as long as I use the correct gauge, But I have only used them for the last 2 years. I have solder joints that are 15 years old yet :D so time will tell. :bmw:
Will let you know if I have any problems with em.
