1 - 9 of 9 Posts
OK, so I decided to swap the passenger seat backs on my 01 and 03. the screws came out as planned on the 01 but one of the nuts is loose and sideways in the trunk lid but that is an easy fix. The question is where does the seat back heater wire run to? Where is the plug and how much disassembly do I need to do to get at it?
This change over is not important but since I put the comfort touch passenger seat on the 03, I would like to have the backrests match.
Larry
Larry
Behind the left hand Speaker housing you'll find the plug
2011 R1200RT
I forgot exactly where the plug is but I recall the whole process was easy and you will easily figure it out as you take things apart.
Your passenger will notice that there is less space for her due to the thicker so-called comfort touch backrest. This may or may not be a problem, depending on the build of said passenger, but it will make a difference. Be sure to have the top case in the rearmost position to help a bit.
OK, How do I get to it?
I suppose looking at the Clymers makes sense but asking is easier if the project is simple.
Larry
Larry
Unscrew the 12 screws inside the trunk lid and don't forget the 3-4 down by the hinge you'll see how the screws are arranged around the circumference of the speaker housing.
I looked closer and realize that several of the little screws are already missing so I decided to leave it alone. I am considering cutting the wires and tucking them. I do not think that anyone would ever miss the heater. My wife still refuses to mount this beast so the heater may never become an issue and the same goes for the thicker backrest. This is for the sake of cosmetics more than heat or comfort!
Don't give up on changing out the back rest. You may, like I have done, found a co-worker who likes to ride. Always willing to ride.
Interestingly, my wife has a sort of renewed interest in riding of late.......
On a really nice day, 72.6* F, no rain, no clouds, no wind, the sun shining from behind us during the entire ride so it isn't shining in her eyes, and the traffic is light, and the road is straight with no curves which require "tipping" to negotiate the curve, then she is good to go.
Loren
Just go to a hardware store and get replacement screws its not a big deal
2011 R1200RT
You can also remove the top case if you won't have a pillion and don't have much need for the storage it provides.
1 - 9 of 9 Posts
