1 - 16 of 16 Posts
Ok, I've read the archives, fuddled through the interpretations of the replies, and at the risk of looking like a total thicky need the clarification.
The following part is from the on-line BMW parts fisch. What I want to do is replace only the rubber over grip on my heated grips. The unit is fine, all I want is the rubber.
This is the part number:
32722332619 handle left $17
If I order 2 of these, pull off the grip and reinstall them over the heated sleeves, is this all it would take to work.
A simple yes or no for this poor soul lost in a black & white world when it comes to his grip replacement needs.
Beryl could do with some grip
G'day Dave,
Going Wayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy back methinks I remember that the left and right side grips have different inside diameters.
Beryl, being a '99 model has some seriously depleted rubber on her bars, so I have tentativly rerubbered her with some tennis racquet rubber grip tape.
In the hot, and also wet conditions we get here, down under, I find that the grips will slide off quite easily,...(not that I let them get that far down the bar). so it would be nice to get some exact replacements but always thought they were not available as an individual item. The belief being is they are supposed to be glued to the heater underneath. The alternative being you are supposed to buy the whole heated grip assembly at a couple of hundred $$......doh! This is not the case for Beryl, at least, soooo if you do find exacty replacements jot it down here.....Beryl could do with some.
Pity about the other totalled one which has good bar grips,....think I would suffer with the ghost of the wrecked unit for decent rubber.
cheers
Phill
PhillWard said:
G'day Dave,------------------------
Going Wayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy back methinks I remember that the left and right side grips have different inside diameters. ----------------------
Phill
No, both grips are the same Inside Diameter. The rubber grip part number mentioned is for a non heated grip, and one removes the rubber and installs it on the heater sleeve of the LT. They are only glued a little at the inside end, easy to get off.
After you replace them wrap them with tennis racket tape and they will never wear out again! Gives you a more cushy feel too.
Excellent, for $34 a set that will work. Thanks for the confirmation!
David, if the grips are not too too bad you can go here: www.beemerboneyard.com/foamgripcov.html they have a rubber sleeve that will slip right over your current grip. They are nice and cushey. Just got a pair and love them.
The ends of the tape have a little sticky tab that works well. Mine are one and a half years old and have not let go yet. You could use a little black tape if necessary. Make sure to wrap the throttle in the direction of the twist so you are not unwrapping it every time you give it the gas. I have found them to give a little more cushion and are completely waterproof. The heated grips work fine through the wrap too.
Hi David , how did you make out with your grips ? I have to do mine , and according to the BMW shop you can't just change the rubber part . They want to sell you the hole grip at 100$ per grip . I told them I read somewhere that you could put new rubber on , but they said they never heard of it .
Anyway did it turn out OK ? Thanks ...patric ...
http://www.bmwlt.net/ubbthreads/showthreaded.php?Cat=&Board=K1200LT&Number=272221&Search=true&Forum=K1200LT&Words=handlebar grips&Match=Entire Phrase&Searchpage=0&Limit=25&Old=allposts&Main=272221
I went through that last year after reading about the grip replacement in the HOW. Same response from the dealer.
The new grip covers worked very well for me, but they are a few mm shorter than what will come off your heated grips in case you're that a.r. I don't notice the difference, and without using any glue at all they have stayed put nicely.
Parts is Parts
:D
www.casporttouring.com/store
Take a look at these Grip Puppies. (See attached pic). I just got a set (I also have heated grips) and they feel wonderful. You'll need to spray a little silicone spray inside one end to get it to slip on easily. (Also, you'll need to trim it to the proper length first.) Took me about 30 minutes to get the first one on (without the silicone spray.) About a minute to do the second one. :)
They feel wonderful. Soft, cushy and easy on the hands. Has a solid grip feel. And, the heated grips are still heated and you can feel the heat too. I accidentally turned mine on the other day (90 + day) and wondered why my hands (thru my gloves) were feeling so warm.
For the LT, get the small like in the picture.
Grips
David, yes they will cause I've done just that and when you put the new ones on roll them back over themselves and then roll them on the grips. Afterwards apply just a tad of epoxy to the ends. Okay roll the ends back over and then apply the epoxy and when you roll them right they'll be safe and secure. I did this just because they wanted to seel the complete grip. The non heated verus heated isn't an issue and mine have been doing great for almost a year now. Enjoy
1 - 16 of 16 Posts
