1 - 20 of 29 Posts
I used the Bosch #72161 from Rock Auto and bought two at the time. I then went to the local Fleet-Farm (Man's Mall!) and took my Bosch filter in to see about a filter wrench to remove the old. I found a CTA RiteFit #A251 wrench that fit perfectly and had a thin sidewall that fits inside the sump on my LT. It was $1.99 on sale and made of steel, not plastic. www.ctatools.com
Now the interesting part. While there I checked the Bosch and Purolator filter books and saw that the Purolator oil filter #L10241 was the listed filter in each book. So I took at look at the Purolator filter and guess what? They are exactly identical except the Bosch is black and the Purolator is white. :confused:
Now I'm not talking that they looked close. They were identical! They both had the same crimps, exterior and when I looked inside, both were identical to include the numbers stamped on the interior where the threads were (3 4 16 L). I mean that they have the same welds and stampings inside, outside and were manufactured at the same place! :thumb:
The Purolator was under $3.00 and I was able to just pick it up and walk out the door without shipping or a wait. Sure the Purloator is painted a different color but with everything on these filters identical except the color of the paint, I'm sure they use the same type of paints.
Now I'm for using quality parts but the only difference is the name and exterior paint. I see no reason why I won't use a Purolator when I change next time. :)
If it is white--is it painted?
You do not want a painted filter that sits in the oil sump-paint may come off and foul the engine. This is not an external filter like others.
While I am for saving money and this is one area that I think LT cost is over the top!
Only thing I always worry about is the internals and what PSI the bypass flapper valve is set at. One company may manufacture filters for a bunch of fitments but to the spec that each call for. Of course the manufacture process would look identical to each other. The specs are what matters and what filtration of particle it will filter or trap.
As far as painted I use Amsoil filters because if I am going to pay a premium, I want a premium filter, and paint has not come off of them that I have seen.
seahabit said:
is it painted?
Aren't all filters painted, or are we talking about powder coat vs paint.
In actuality the answer is no. The BMW specific filters only have ink on them to denote what they are when you pull them out of the box. I've seen other after market oil filters that are not painted also.
I use Bosch, BMW, and Amsoil filters. I've had experience with the other filters, so I stay with what I trust.
I've never seen paint soften or come off any filter from oil. The bypass pressure setting of the internal relief valve should never be called upon to do anything - unless the engine is shelling out & filling the sump etc with debris. In which case you have more serious problems than oil filter issues.
Otherwise engine oil filters generally don't have that fine a micron particle rating - typically about 15 microns nominal - ~ 40 microns absolute as I recall from my hydraulic days.
5 micron on an Amsoil and I believe the BMW is 5 also.
HD is on 5 microns too I believe.
And if your relief valve is too lite, then most of your oil will bypass the filter and go unfiltered, not a good thing at all.
That's probably a "nominal" (what is the filtering efficiency at 5 microns?) rating - not an absolute. A 5 micron filter in hydraulics to handle a few gpm has to be much larger - and hydraulics don't have such heavy oil in a start up situation.
Filter bypass is routine in engine cold start situations. Most of the oil blows over the relief valve under these conditions anyway.
The BMW filters seem to be unique since they have a fine mesh screen in the bypass so that the bypass oil gets some filtration (but obviously not in the 10-40 micron range.
They also have a strong spring in the bypass valve.
From my limited experience with Purlator oil filters - over 90,000 miles between my 2002 LT, 1985 K100 and 1987 K75. I've had zero problems with the Purlators. I've never seen the paint come off of the filter body. I do change oil every 5K miles using good old dino GTX 20-50.
Some years ago Purlator made the Pure One without the grip coating - I'm upset because I did like the Pure One filter better, it had a better micron rating. My logic is change every 5K miles with dino oil - it does the engine good to keep fresh oil and filters in there.
Didn't want to get anyone going about quality of fiters and I apologize if that's what happened. I just wanted to let some in on an observation and a possible alternative should some decide to give it a try.
In regards to the paint, one is painted white and the other is painted black. If anything were to come off on the exterior it should collect in the filter first before going onto the rest of the motor. But Ive never seen any paint come off of one before. Some even forgot to peal the sticker off of the Bosch and went back into find the sticker still intact.
When you look inside at the bypass valves or whatever they are, they were identical right down to the visible welds inside. I have no doubt that all the reputable brands out there meet similar high standards. Many folks have their favorites and by no means am I trying to talk anyone out of their own piece of mind. I don't want to confuse this like a oil thread as to who's is best and and what is junk. But this may be some useful info should a rider find themselves out somewhere and need a filter and oil for a quick change before getting back home. I mean when many get their oil at the -mart stores, they might be able to grab one of these filters too. It might get you out of a bind should a filter be needed.
As far as microns of filtration, heck if I know what is what. I'm the wrong guy to ask that and often been changing oil and filters on all my cars with what's been on sale. I just change my oil often and every car I've had has gone 120,000 miles or better.
As for K & N I've used those too and they are great filters!
I've also though I read somewhere that the Bosch filter #3331 also fits the LT and that happens to be a filter that fits my Regal. (I'm not saying the 3331 will work on the LT)
Again, just an observation and don't want to raise any hackles.
If you get your LT hot enough to melt the paint off your oil filter, I'm thinking you have been running too fast and are probably vaporized at this point................ :eek:
My stupid question of the day...
Do all of you run the OEM filters on your cars?? How is the LT engine different than the majority of the small car engines built today? Most of them are water cooled aluminum, DOHC engines also.
Roy
Old Slow Guy in A Fast Car
Roy
Roy the BIG difference is Most cars DO NOT have it's oil filter INSIDE the engine. It is on the OUTSIDE of the engine. So it DOES make a difference on what filter you use IN the LT.
The PO of my bike ran the Bosch filter. When I did the first oil change I noticed some of the paint was off the filter so I have never used the spare Bosch filter he sent with the bike because of that. So what most of you are telling me is that the Bosch filter shouldn't normally do this.
Use the cheapest filter you can find. Don't worry about paint and microns and let me know when you hear about an oil or oil filter related failure on an LT.
I had my local auto parts house order a Bosch 72161 and it came jet black and certainly looks like it is painted. Anybody else have that experience?
Denny
I got the Bosch 3330 at AutoZone and it was black and has a sticker on it. The STP filter that crossed with it had no backflow preventer in it. It was $6.49 but they were on sale with some Castrol 20W50......... :D
1 - 20 of 29 Posts
