1 - 2 of 2 Posts
I was trying to take off the front vent portion - (the fairing part that funnels air to the oil cooler). I was going to put a screen behind it to keep the oil cooler cleaner. I'm tired of cleaning so many bugs every ride. I found out that there is a screw right in front of the oil cooler that looks impossible to get out without removing the oil cooler, Is that the case, Is removing the oil cooler the only way to get that piece off? There is only about an inch clearance. Or is there some ingenious way to get it off.
Screen wire will impede air flow.I use a piece of dirt bike foam cut to fit.Does not impede air flow and stops all bugs.To clean simply remove , wash , and reinstall. Works great for me .
1 - 2 of 2 Posts
