1 - 11 of 11 Posts
Ok, I probably have seen this on the old site, but can't remember where, so I am sorry for the repeat...
What is the consensus for normal oil consumption?
My bike is a hair under 13k and just took 1/2 quart at 1,600 miles since last oil change. Normally park on the sidestand and just 'normal' riding around this part of Oklahoma - no 2 up or hot-rodding (well, maybe a little)... ;-)
12k valve check as A-ok and plugs looked like the pictures I had seen here of normal plugs at 12k.
Just wanted to know if I need to be concerned.
oil consumption
at about 11,000 miles I did a 2200 miles trip to Florida from Kentucky and used about 1/3 qt of oil during the trip.
I have 48K and I typically don't add oil between changes.
I have added some if I am running cross country at high speed... into heavy winds... and then only a few ounces.. but in the Northeast I have yet to add oil between changes...
I also rarely smoke on startup except if I ran it had and shut if off and left it for the night on the sidestand.. and then only occasionally..
Hey Shawn - leetle bitty booklet sez "Maximum oil consumption = one quart in 580 miles OR one litre in 1K kilometers", so I'd say you're well within the max.
One of these dayz, I'm gonna measure the drained oil and compare it to what I put in (I alwayz put in a measured amount), just to see if there is any appreciable consumption on an engine with 100K+ mileage. My riding style seldom varies 'tween fluid changes.
Anyway, Shawn - just thought I'd mention what BMW puts in the booklet re; consumption max.
Discussion Starter · #6 ·
Thanks for the feedback guys... I should have read the book (insert embarassed smiley here).
I thought about measuring what I take out also Dick - I think though that would require me to not be oiling down the garage floor though during the oil change... ;-)
Yeah, I know - it's gonna be a 'messier' job when I do that, butt what they heck - neatness ain't in my vocabulary!! BTW - if you haven't already, buy yourselvis some blue 'Nitrile' surgical-type gloves (not the latex greens) - most NAPA stores, or parts houses have 'em. They letcha make a beeg mess, butt it don't get under your fingernails!!! They're talcum lined and comfortable, and you still have grippage for picking up dropped thangs.
I was frequently topping up on longer trips until I had around 12K on the bike. With 18K now I never seem to have to put oil in. I have also noticed that the more miles I have on the LT the smoother it seems to run. Maybe theres something to that 18K break-in period.
They're talking burning a quart of oil to every two tanks of gasoline here. Maybe that was acceptable back in the old days, when your Harley-Davidson or Triumph engine leaked almost as much oil as it consumed, but if my 2004 BMW motorcycle was using that much oil, I'd be pounding on my local dealer's service desk, demanding something be done about it. With a modern engine in good condition, I would not expect to have to ad any oil between scheduled service periods.
I use Mobil-1, and change my oil and filter every 6,000 miles.
My bike broke in nice and hasn't used any oil between changes (3,000 mi w/BMW dino 20W50) since it was new 44K miles ago.
My last bike was a K1100LT. It used a little bit (few ounces) between changes until it had about 10K miles then none.
1 - 11 of 11 Posts
