That few you think?JGroves said:You're going to get at least a dozen different opinions on each issue...
Well, if you're using ****** you don't HAVE to, right?copperstatetour said:That few you think?
I decided to stop chaning my oil. Since there is so much disagreement on the issue I don't know what to do and so I have defaulted to doing nothing![]()
:histerica That's what ole Toad has used since 2000. I keep forgetting how to spell it, so I just ask for ******!!!! :histericaJGroves said:Well, if you're using ****** you don't HAVE to, right?
(Just kidding, ****** guys. Really...)
Edit: OMG they blanked it out. That says it all!!
dukester said:Any ideas what the oil change frequency should be and what type of oil to use? Also, any information on kits for the LT oil change would be appreciated.
A new oil thread AND a new tire thread in the SAME day... You guys have already made my week.r_figueroa said:Has anyone had experience replacing the original Metzlers (which I believe are bias-ply) with radials such as the Bridgestone Battlax? Any changes in handling, etc? Suspension is stock, no changes (at least not yet).
Spinach? Really? :histericaibbones said:Come on...somebody has to say what Popeye uses.
It's just like old times.Beemerick said:A new oil thread AND a new tire thread in the SAME day... You guys have already made my week.
BMW specifies crankcase oil changes at 6000 miles. Tranny and FD at 12K miles.dukester said:Any ideas what the oil change frequency should be and what type of oil to use? Also, any information on kits for the LT oil change would be appreciated.
Frequency is 3.17E-8 Hzdukester said:Any ideas what the oil change frequency should be and what type of oil to use? Also, any information on kits for the LT oil change would be appreciated.
Dino or synthetic?rattler50 said:If you don't use Castrol 20W50 your engine will explode................ :kaboom:
Around here you can't even put a floor drain in a garage anymore on a new build!K100Dennis said:Dino won't explode 'cause it's already been in an explosion when the Big Bang killed all the Dinosaurs, or was that before ,............. anyway they're all dead and that oil is from their pooh, and it's good enough for the job. I think it needs to be tipped back into the ground when you're finished with it, 'cause that's where it came from. Hope this all makes sense to someone.
O.K. I' ll switch to synthetic ASAP!K100Dennis said:Dino won't explode 'cause it's already been in an explosion when the Big Bang killed all the Dinosaurs, or was that before ,............. anyway they're all dead and that oil is from their pooh, and it's good enough for the job. I think it needs to be tipped back into the ground when you're finished with it, 'cause that's where it came from. Hope this all makes sense to someone.
