I changed the oil yesterday and have done this a number of times. I dropped the oil filter and lubed the new oil filter and replaced O ring for 3 screw torx head cover and tighten to specs. When I went outside I found oil coming from 3 torx screw cover for oil filter, about the size of 2 half dollars on the floor.
I cleaned the bottom off and about 3 hrs later had a small oil leak about the size of a quarter on the floor.
When replacing cover does anyone think I could of pinched this O ring or any other thoughts of oil leak. I am using Amsoil 20w 50 I was thinking about dropping all of the oil and replacing O ring and refilling with the same clean oil using a clean pan.
Kevin
Alton IL
Kevin
Alton IL
