Is a blue oil fog common after resting the K12LT on the side stand. If yes, how quickly should the "oil fog" burn off. My '03 LTE with 21K looks worse than a 2-stroke for up to 5 miles after storing the bike on the side stand over night.
I'm not an oil expert (and I'm sure there are some guys here pretty good), but I will assume that because synthetic is thin then mineral, it will 'leak' in a bigger quantity to the pistons then the mineral.wjpatter said:I have a 99 and changed to synthetic oil for the first time last oil change. Without exception, I blow smoke to the first two – three minutes. This is new. With non-synthetic oil, I would occasionally blow smoke, maybe one out of ten times. I been reading the threads for a while and don’t remember seeing any correlation between smoke and synthetic oil. I’d be interested in other experiences.
Bill Patterson
"almost right" is a lot better than i normally do. just ask my wife!dshealey said:You are almost right.![]()
