Any suggestions on modifying K1200LT negative battery cable to best attach to new Odyssey P680 battery? Currently using thin brass L shaped bracket supplied with battery and a brass spacer washer. Not completely satisfied with the connection so I am reaching out for suggestion. Thanks
IBR# 366
I just rotated the negative battery cable flat to fit the Odyssey terminal, then screwed it down.
Did the same for the positive cable.
Discussion Starter · #3 ·
My negative cable has a sodered in threaded screw attached per photo below
Motor vehicle Electrical wiring Gas Automotive exterior Electrical supply
