odyssey batteryfailure
The following was copied from the Odyssey online site.
http://www.odysseyfactory.com/odycharg_c.htm May help you understand the charging reqirements of this baterry.
Also you may want to contact them via this site concerning your failure.
RECOMMENDED CHARGERS FOR POWERSPORTS APPLICATIONS
(PC535, PC545, PC625, PC680, PC925)
There are two types of chargers for powersports applications, depending on the way the battery is used. The first type is the cyclic use charger, required in situations where the battery will be deeply discharged each time and must be recharged relatively quickly. All recommended chargers can be connected and operated indefinitely.
The second type is the storage use charger, required when the battery must be maintained at a high state of charge. Custom V-twin motorcycles are a typical application requiring this type of charger. These bikes are typically ridden for short distances and the battery has to provide multiple starts. Several days’ of this type of usage causes the battery to fail prematurely due to insufficient charge. A storage use charger must be connected to the battery whenever the bike is not in use. This will keep the battery at a high state of charge and eliminate premature failure due to repeated undercharge.
Charge Time Manufacturer or brand name Part Number Output (Volts & Amps) Contact
8 - 12 Hours
TecMate AccuMate Pro 12V-7A-S 12V, 7A Motion Pro Inc. 650-594-9600
Xenotronix SX 90-1 12V, 6A1 Xenotronix
800-624-9366
12+ Hours Motocell™ 693601 12V, 3A Custom Chrome 800-729-3332
Battery Defender ACC-1206WB 12V, 3A BatteryMart.com
800-405-2121
1 The 12 amp charger (see next section) is recommended for the PC925 in cyclic applications
RECOMMENDED CHARGERS FOR ALL OTHER APPLICATIONS
(PC925, PC1200, PC1700, PC2150)
These larger ODYSSEY® batteries may require deep cycle as well as storage charging. The following table therefore shows the range of chargers and the largest ODYSSEY® battery each can be used with.
Charger type Manufacturer or brand name Output(Volts & Amps) Part Number ODYSSEY® sizes
Cyclic use Xenotronix 12V, 12A TBA Up to PC925
12V, 50A TBA All sizes
24V, 30A2 TBA Up to PC1700
36V, 20A3 TBA Up to PC1200
2Two ODYSSEY® batteries must be wired in series for a 24V charger
3Three ODYSSEY® batteries must be wired in series for a 36V charger
