I seriously doubt it could be made to work without extensive engineering. Not worth the effort to try.ehaughn said:Thanks for the info.
I was curious if the OBD2 device I have, can be hooked up to the LT.
Can I convert the barrel connector to a 16 pin and would this work?
Not sure what protocol it uses.
Maybe it does not support any of the OBD2 protocols?
deanwoolsey said:It does not. While the systems are very similar from what I see, the BMW uses a round connector for the GS911 tool and the OBDII systems use a trapezoid connector.
