Hi all;
I found some Bosch O2 Sensors on Ebay. Price is OK ( 70.00 US).
I think this is the model I need for my 2005 LT.( anyone know for sure??)
Length look good, around 12" long cable.
Anyone else looking for these??
ebay number: 110487422517
I plan on getting one shipped Sat or Monday.
Just letting everyone know!
Regards,
Bowdon
bowdon said:
Hi all;
Regards,
Bowdon
Check out this Thread
The original BMW part # is 11787671757 for the '05. The one you reference is for the earlier models. :(
PMitchell;
I read that thread, and if I read correctly, this sensor should work on the 05 also, unless I have read wrong!!
Regards,
Bowdon
PMitchell said:
Not sure. Got the part #'s from this site under exhaust systems. (LAMBDA MONITOR SENSOR)
http://www.maxbmwmotorcycles.com/fiche/fiche.aspx
I know I read this, but I was looking for one local.
It looks like the number from BMW is different but the same sensor should fit alll the LT's.
I have read that some use the bosch 15109 which seems to work for the 2005 and up.
The BMW number for 99 to 2004 is: 11781742051.
For 2005 and up its: 11787671757. Parts look the same, except for the different number.
Wish I had the right number for the bosch!!
I guess I will wait till I hear back from the dealers and/or someone on the site.
Bowdon
A good web site for this information:
Oxygen Sensors / Lambda Monitor sensor
http://www.euromotoelectrics.com/
O2 Sensor - Lambda Monitor sensor
Personal note::
K1200LT - The BMW 740i (97 - 01 v8) the car is same as the bike. There is a list out there on cars with V8's that use the same O2's as bmw bikes.
Price ranges from $60 to $125 --- Not the dealer price at $225.
Lambda Monitor sensor:
Year --- Part number --- Length inch / mm
1997 to 2004 --- 11781742051 --- 17 / 432
2004 to 2013 --- 11787671757 --- 18.5 / 469
-K1200LT -- Length inch / mm 17 / 432 and 18.5 / 469
Vehicle Manufacturer # 11781742051
Part #: O2-E051 EnDuraLast Denso Heated 4-wire Oxygen sensor for BMW K1200LT
Part #: O2-051. BOSCH Oxygen Sensor for K1200LT models
-R1100, R1150, K1200 -- Length inch / mm 31.5 / 800
Vehicle Manufacturer # 11781341022
Part #: O2-022. BOSCH Oxygen Sensor for later BMW R and K models.
Part #: O2-N022 NTK's
Part #: O2-E022 EnDuraLast Denso Heated 4-wire Oxygen sensor
-R850, R1100, K1, K100, K1100 -- Length inch / mm 23.5 / 597
Vehicle Manufacturer #11781464492
O2-492
O2-E492
-G650, HP2, R900, R1200 -- Length inch / mm 6 / 152
Vehicle Manufacturer #11787674452
O2-N452
O2-E452
-K1200 -- Length inch / mm 18.5 / 469
Vehicle Manufacturer #11787671757
O2-N757
O2-E757
- F650, F800, HP2, K1200, K1300 -- Length inch / mm 16.5 / 419
Vehicle Manufacturer #11787672785
O2-N785
O2-E785
Replaces All heated O2 sensors
4 wire
Part #: O2-ET347 EnDuraLast Denso Heated 4-wire Oxygen sensor
