Hello Printman
Not in my experence , when my O2 sensor went bad the only posivitive indication was poor gas mileage , around 35MPG , plugs black and sooty and too much black smoke on hard exeleration . About $50 at autozone , some place on this site is the part # for a BOSCH that has the correct connector ,
BobG
soooooooooooo after replacing the fuel filter, re-doing the injectors. what do you guys think is causing the engine to cut off at idle
just thought of something bike is a 2000 with 13k miles replace the plugs with NK not botch think maybe is the plugs or should I replace the spark plug cables
Here is a little trick to check the wires. Get a spray bottle with water in it, mist the wires at night. Start her up and you will know right away if the wires are going bad, it will be a great light show down there. Now don't drown the wires, just mist them. :bmw:
