Hi all,
I hope someone can answer this question for me. I have looked everywhere online and the owners manual is no help.
I have the Nolan BT 2 setup and I'm trying to figure out what the output voltage is on the charger.
The reason I ask is I got its charger mixed up with another in my charger pile and now I have two chargers with the same connector but one is for 5VDC and the other is 9VDC.
If you have this setup, could you please relay the data off your charger to me.
Thanks much,
Bill
Don't have one to check, but I'll be amazed if its not the 5V charger. Someone should come along soon enough to answer for sure...
I have the BT2 setup and here's the fine print on my AC Charger:
Model: FY0901000
Input: 100-240VAC 50/60Hz
0.3A(Max)
Output: +4.2VDC===0.4A
Hope this helps and good luck!
Thanks, Outlier, that's what I was looking for!!!
Regards,
Bill
