1 - 20 of 23 Posts
I ride my LT with a Zumo and XM radio. With helmet speakers it was almost impossible to hear anything even on the loudest settings. I love to ride with ear plugs so I tried a pair of radio shack in ear spekres just to see. WOW what a difference. However they still don't block out enough of the road noise, nor do they stay in very well. Does anyone have any expierence with noise isolation earphones. I'm not looking to spend the $1,000 for Ultimate Ears but do believe this is the way to go.
my experience has been that the helmet speakers are all but useless, unless they are positioned directly over the ear hole. My autocom install placed the speakers to far back and it was difficult to enjoy the tunes. relocation made a huge improvement. also the position of the wind shield in relation to face shield either increases or reduces wind noise.
Have not yet purchased ear speakers, but have been told they are a great improvement and much more comfortable.
I've used many different kinds of helmet speakers and earbuds and I believe the best combo is earbuds that use the foam inserts you roll up, press into your ear, and let expand to the shape of your ear. Just like the cheap earplugs I have by the score in every pocket, bag, and extra space, and which I use when not listening to an audio source. As far as active noise isolation, I think it's great, but expensive.
If you can just block most of the noise coming in to your ear, your audio source will sound great and can be at a lower volume.
Remember the most important aspect of this: Whether or not you have audio coming in, reducing noise will reduce stress (studies have proven this) so you will be alert and best able to concentrate and enjoy your ride! :bmw:
My recommendation is that you contact a fellow BMW motorcyclist named Bob Weis at The Earplug Company.
http://www.earplugco.com/
He sells what I refer to as in-ear monitors and while not inexpensive, are the only way to go as far as I'm concerned. Not only do the earplugs attenuate wind noise and other ambient sounds, the audio quality is second to none. I've found these to be incredible on long trips and they are truly the first thing I pack. Love them so much I scored a second pair for the gym as I'm not a fan of headphones or those uncomfortable iPod ear buds. On his web page look at the Challenger C's - as he states, not for the faint of heart!
These are custom molded to your ear so impressions will have to be made and sent back to Bob. He sells a kit to make things easier if you don't want the hassle and expense of going to your local audiologist. I think it was worth the wait as they fit perfectly under your helmet.
A word of warning, these monitors will spoil you for good. Like sipping a finely aged tequila versus shooting that Jose Cuervo lighter fluid, this will open your eyes.
Give my best to Bob!
David
I recently attended a BMW group ride in Death Valley. We stayed in Beatty Nv...a rider known as Arizona Al....was custom fitting the "in ear" type earphones in his motel room....the unique part was the lines going to the ears were tubes ( 1/8" ) I did try the air delivered sound and was quite surprised at the quality...users commented that they totally eliminate road/wind noise...while still allowing hearing sirens/emergency type sounds....I will look for his card and re-post.....$65 for the ear pieces.....$200 for the source.......1 advantage was being able to replace the 1/8" tubes easily if necessary.....
Maybe someone else on the board knows him???
I ride with custom made plugs. It was the best $75 I ever spent. You can go to your local hearing aid guy and they can also make them if you don't get them made at a show. I can hear the ipod better and other noises other then my wife in the headphone. But I am not stressed with all the road noise and also the benefit of not hearing my wife telling me to slow down.
In the ear speakers are the way to go.
Helmet speakers combined with earplugs isn't bad, but you have to crank up the audio volume to the point of distortion.
If you are going to put in earplugs anyway, you may as well put in wired earplugs. I did get a custom set made at CCR Braselton which were very comfortable but they didn't last long, develped a short and I trashed 'em. http://plugup.com/cart/
I now use an earlier version of these:
http://www.aerostich.com/navigate-communicate/audio/earspeakers/er-6-earspeakers.html
I did try the much cheaper Koss ear speakers, not comfortable, didn't isolate sound so well, and I gave up on 'em.
Then I got the ER-6 earbuds. They came with a variety of different sized and different material foam and rubber plugs. After some experimentation I found the right plug for my ears. Now very comfortable, great ambient noise reduction, and great sound.
I would suggest trying these, or have a custom made in-the-ear speaker made by an audiologist. It was Marylin at CCR who made my custom ones. They were very comfortable, and the sound was good BUT the quality of the components were poor compared to the ER-6 and the wiring developed a short. Sooner or later you are going to accidently tug on the wires and they need to be made rugged enough to take a bit of that. My custom ones were not very rugged. The ER-6 I have been using for years and are doing well. I did have to fuss with the ER-6 ones more before I found the comfortable fit; the custom ones were comfortable from the start.
YMMV
I purchased two pairs of Challenger earphones from Bob in 1999 and they are still working like the first day.
His later models are now better as the cable that goes to the ear are a lot thinner than the ones I´ve got, which are the same size as the main cable before it splits into two.
Highly recommended.
I use roll up earplugs with the highest noise blocking rating I can find. Use the cheapest helmet speakers Aerostich sells. With the ipod adjusted correctly, plenty loud enough to hear at any speed, GS or LT. Most songs I actually turn it down a bit so I can still get some other noise into my processing center. In town traffic, I turn it way down so I can hear horns and sirens etc.
dwsdad said:
You could also go this route: http://www.earfuze.com/store.html
I haven't used them, but they do look interesting.
+1 on earfuze. Reduced expense since you mold them into your ear yourself. I've had them for 2 years and are still in great shape. They halved the road noise and the volume necessary from the MP3 player.
Jer
I had the same experience listening to XM through my Zumo. I talked to a vendor at the Finger Lakes Rally last September and had a pair of iPlugs custom made. The company is E.A.R.Inc at earinc.com. IIRC they were about $225./$250. but worth every penny. I didn't know what I was missing.
Ride Safe,
Wade
+1 on what Charlie VT says. Etymotic ER6 in-ear headphones. Multiple, washable, replaceable silicon seals to keep out noise and provide great sound + replaceable ear wax filters.
They attenuate about 26db.
Hi all;
Just wondering it these ear plugs (wired) work for mic's on existing helmet headsets?
The cable ( 6 pin with adapter) is ok to hear but to "talk" to the passanger??
Bowdon
bowdon said:
Hi all;
Bowdon
As I explained in my post earlier in this thread I use this connector http://www.sierra-mc.com/proddetail...rod=JM-HC-ZJM-S which enables me to connect my in ear isolation headset to the stock intercom. With that I can talk thru the Helmet mike and listen thru the in-ear speakers. Works perfectly
Jer
I started a thread last week on this topic. I ordered a pair of the Earfuze ear thingeys and have found them to be remarkable. I have about 4 hours highway time on the now and as I was on a 3 hr ride I was trying to figure a way to explain how effective they are.
I was riding 65mph on a secondary road 51* F, windshield all the way down and the chin bar on my Symax II in the up position. The music I was listening to had a passage with a flute solo. The volume was set at a position that would be comfortable sitting in my living room. Not only was the flute solo easy to hear, I could actually hear the flautist draw in his breath between intervals. They are truly that good.
$34 deliverd to the door. I will pick up a spare kit and leave them in the tunk. If someone is going to ride pillion with me for 1/2 day or more I will mold them a set on the spot.
They are perfectly aligned every time, they stay in place when I put my hemet on and take it off and they are comfortable.
I like 'em!
Loren
Just tried the earfuse product. Impressive!
Wrote them a note with a question:
"Just tried out your earpieces. Great product. Easy to set up and use. I have a question:
Your ear buds are good, however I generally use a set of high end buds and comparing the difference in the audio characteristics I am thinking of using your mold material in combination with my ear buds. Can you see any problem with doing this?
Thanks in advance,"
Kimble Neel
Phoenix, AZ
Will post the reply.
1 - 20 of 23 Posts
