1 - 13 of 13 Posts
I'm currently a RT owner and have found a 02 LT that I'm considering adding to the stable. On my test ride I noticed that when weaving or cornering that there is a moderate vibration coming up through the frame/handbars. My first thought was the tires (ME 880 getting near end of useful life) and then I noticed the left hand turn/weave/lean produced the vibration a bit more pronounced. Could still be the tires but with all I've heard about drive shaft failures, thought I'd throw the question out. BTW with the bike on centerstand the rear wheel indicates no play at all side-to-side.
Any play at the 12 o'clock/6 o'clock position? When mine was doing that I needed new pinion bearings in the final drive.
Me880's are NOTORIOUS for being noisy when worn...
I'm sure that's the issue you're having.
Tire time.
Tire time.
+1. Near the end of my 880's life span, I have the music loud! :D
Also get the vibration while cornering too.
I had the same when the front tire was cupped and when the rear drive was ready to go. Not at the same time -
9200 miles on my ME 880's and they are getting louder in turns.There is no vibration felt in the handlebars or anywhere in the bike. Welcome to the LT riders group!Robert.
Probably the tires. How many miles on the 02 and how much are they asking? None of my businessI know, but an 05 or newer may not be that much more. I have an 02 and love it, but I have put nearly every mile on it and know the bike.
A normal wear pattern will cause more noise in a left turn. Probably just the tires. If you spin them and sight over the tread any movement perpendicular to the direction the tire is turning translates into noise. The bigger the scallop, the bigger the noise. Hell, I had no idea how quiet an LT is until I replaced my Avons.
he he he.. I liked the noise... makes me feel like a x wing pilot strafing.
yeh time to replace as well.
dang they are getting expensive , arent they?
54K miles for $6100. Pretty clean bike.
I told myself after my first set of 880s that I would never buy another set for just that reason. The problem I found is that I could find no other tire combination that could give me the mileage of the 880s. I'm now trying a little higher pressure to avoid the wear that yields the vibration. The LT is very sensitive withered excellent feedback to the rider for such a heavy bike and so you get the bad with the good so to speak.
Tire time.
Yep, +1.
I had similar noise issue on my Kawasaki Voyager running Dunlop K491s and Michelin Touring Elites. I think all tires make more noise as they wear.
1 - 13 of 13 Posts
