Hi Folks!
I just purchased a 2006 K1200LT with 41,000 miles on it yesterday. I plan on doing some key maintenance on it. It’s been maintained well with records but there are a few things that need to be addressed.
1) I smell some fuel on startup and have read about the quick disconnects going bad etc . I’m not sure when the fuel filter was replaced either. It sounds like I should upgrade to steel quick disconnects and replace fuel filter? anything else fuel related?
2) The general warning light on the dash( Red triangle !) stays lit up. It appears that is due to an ABS fault? How can I confirm?
3) It has the stock brake lines and I plan to install Spiegler. Considering item 2, I’m now wondering if I may need to bypass the ABS pump? how to confirm?
4) It has a boosterplug on it and I’m considering John John Gemi ’s chip. I’m assuming John’s chip is better and not compatible and the booster plug needs to be removed? Do I then need a new intake air temp sensor? ( the original did not come with the bike)
5) The BMW GPS keeps glitching out and wanting to do a screen calibration and save a favorite while riding.. are these known to have issues? Or do I perhaps just have a bad electrical connection? Curious on experience with these units.
6) Are aftermarket exhausts still available?
7) It has the xenon headlight and it appears the high beam isn’t working, what are the best and brightest bulbs?
Can the variety of OEM bulbs be replaced with LEDs? Will the dash light up with a warning ? Do I need resistors?![]()
9) With the bike apart and the tank off, are there other maintenance items or upgrades I should perform?
Thanks in advance for the assist!
Dave View attachment 182480
Hello from a 3 month long owner-You have my preferred color on one of these mine is a 2000 in a Pacific Bue-ride hard my friendHi Folks!
