1 - 2 of 2 Posts
I really messed up! Forgot to pull the plug off of the coil while removing the gearbox on my 03. Does anybody know the wiring order of the three wires going to the coil
OK Pin 1 is the brown wire, Pin 2 (center) is Green wire and Black goes to pin 3.
If you can't read the pin numbers just put the green (switched 12v) to the middle pin and try the brown and black on the out sides - if it doesn't start swap the brown and black wires. You won't hurt anything if you get it backwards - it just won't run.
1 - 2 of 2 Posts
