I do not have a 2002-2004 model here to test my theory (to confirm starter interlocks behavior in a specific condition) .... SO could any one having such model do this simple static test (no start is required).
Step by steps:
(1) with ignition OFF, transmission in Neutral, engage the Reverser knob in reverse position (you may need to rock rear wheel back-forth)
(2) set the kill starter switch in Left or Right position (basically anything but center)
(3) turn ignition ON, wait 6 seconds for ABS self-test to complete. Note that RED engine-temperature warning on dash should be OFF at this point.
(4) move kill-switch to center position (do not start): when switch is moved to center, take note if you see either or both of these signs:
a) did you hear fuel Fuel-pump priming sound for 2 seconds ??
b) is the RED engine-temperature warning still OFF ??
Test is complete, you can shut ignition OFF now.
Let me know results of last 2 items a) and b) above. THANK YOU!
P.S.: Do not forget to move the Reverser knob back to normal position after you shut ignition OFF.
Step by steps:
