Has anyone installed a Navigator III in the older LTs (99-04)? I am making a separate thread on this topic because there may be some interest in installing these units in the older LTs. My 02 does not seem to have the factory wiring. Sometimes, older bikes have the factory connectors in anticipation of the newer bikes having different accessories such as the Navigator. I would like a wiring diagram of the Navigator system so I can figure out what wire goes to what on the unit so I can splice it in to my radio.
there used to be lots of threads on this sort of stuff, don't know what happened to them, Do not splice the gps into the radio speakers you will blow the GPS audio circuit. I tried it years ago. take the power from the map light and earth it there, that switches off the gps when you lock the ign. Personally I use a $100 car gps and have done now for years
Edit found them here
all files are here
Reactions: Nil_Time
The Nav III is long obsolete, short on memory for modern maps and has no external storage capability. I can't think of one good reason to add one to a bike that isn't already set up with a mount and cradle for it. Even then, I would upgrade to a current model.
Reactions: DanDiver and JNW003
I added one on my 08 K12S....plug n play. I like it. Works great. For the LT I can use the Navigator 3 and my phone GPS to help me navigate across the country
The answer is....yes....a Navigator III can be attached to a 99-04 LT.
I tapped into the map light (remove windshield, and remove trim piece behind instruments) and routed the 2-wire harness around the left side of the dash. I found a 2-wire connector at Pep Boys, meant for an alternator and soldered the connector to the end of the wire. Now the bike is ready to accept the Navigator connection, but I needed to prepare the stingray to mount the unit.
In order to prepare the stingray, the little BMW logo is removed by gently prying it up.
The stingray has to be taken apart by unscrewing 6 torx screws and a few phillips screws. Underneath the logo is a sunken area that is exactly the size that needs to be drilled out with a hole saw or step bit, which I used. The GPS comes with a little plate that can be used as a template to mark and drill the 4 mounting holes. After drilling the holes, the GPS mount can me bolted to the front section of the stingray.
The wiring has to be routed BEFORE you attach the GPS mount. Now the cradle is bolted to the lower mount, and the GPS can be mounted inside the cradle.
Here is the wiring routed through the bottom of the stingray:
Here is the Navigator III mounted to the stingray:
I connected the wires from the stingray to the bike, including the Navigator connector and everything worked. The Navigator sits just above the radio display and just below the dash lights so everything is visible. My unit came with a sunshade which keeps glare to a minimum except i the sun is directly behind me.
I can understand if you already have a Nav III cradle that buying another Nav III might make sense. However, if you have to do wiring, I am at a loss as to why anyone would want an obsolete device that can't be easily loaded with current maps and can't hold enough of the new maps to travel more than 500 miles from home.
Once I found that the Nav V was completely plug and play with my Nav III equipped LT, upgrading was an easy decision. If I had an older LT, I might forgo the Navigator and just get a Garmin branded motorcycle unit and save a couple hundred bucks.
My last long trip with the Nav III was PA to Newfoundland in 2015. I found a way to load the current maps using a combination of new and old Garmin programs, but I barely could load enough map regions to get from here to NF. Even the eastern US was far too big. Every trip required me to plan the route and then pick map regions that just covered that route. Any significant detour off the planned route and I could easily run out of map. Got to be a real PITA.
Voyager has the right idea. I donated my Nav III to a Curve Cowboy Reunion charity auction and I think it went for about $20 for the entire system. I kept the mounting brackets like shown on your stingray on the washing machine, and installed a Garmin 590LM. The Nav III unit was pretty much useless on my last long distance trip, as the maps were so out of date, it was missing gas stations, hotels, roads, housing areas, etc. and frustrating to need to stop to pull out the smartphone for directions. The 590 solved that problem.
Reactions: Notahog
I wouldn't waste the time on a Nav III. It's very slow on recalculating and that's just the start. Get something a little newer that you can use and not get frustrated with.
