How do you delete a Favourite folder on the Nav IV? You can delete way points but I haven't found a way to delete folders in the Nav IV.
Garry
Garry
I know this for Favorites but I want to delete the sub folder they are in. Maybe you have to delete all the favorites in the sub folder to automatically delete the folder.To delete the favorite
- touch the favorite to highlight
- below the GO! there is a edit tab button - touch edit
- then touch the delete tab at the bottom
- then confirm the delete
Hope his helps
Dennis
Favorties or organized by Category. A Category will automatically go away when there are no more Favorites in it.I know this for Favorites but I want to delete the sub folder they are in. Maybe you have to delete all the favorites in the sub folder to automatically delete the folder.
Garry
That will not work. As noted above, Categories are not represented by folders on the file system. And you can't delete Favorites or Routes from the Nav IV internal memory from the computer.Did you try connecting the GPS to a computer and opening it to show the folders then delete ??
